RF Measurement Devices
Missing VI - RF Record and Playback Reference Application
Tried to load and run "RF Record and Playback Reference Application" just posted on Developer zone.  Have all correct versions of SW.  Missing MITEoptimization.llb containing optimizeMITe.vi.  Found the win32fileiovis but still missing this one.  Reference to "file below" on web site but not there.
(7,556 Views)
Hi Phil,
To combine the "RF Record and Playback Reference Application" Example with high-speed data streaming to and from hard disk arrays requires the Win32 File IO LabVIEW VIs.  You mentioned that you did find these, but perhaps you did not download them from the proper location.  The Win32 File IO VIs can be found here.  The downloadable ZIP file on this page does contain the MITEoptimization.llb with Optimize MITE.vi.
Andrew W
(7,543 Views)
Thanks, Andrew.  I do have the files, but the strangest thing happened.  Although the locations of the web page linked to as well as the file locations appear to be identical, the file that is downloaded is different depending on whether I link to it with Firebird browser or IE.  Same behavior whether I double click on the file or right click & save as
File sizes are 383KB  (short file) and 628 KB (complete file including MITEOptimization and benchmarking files)
Using Winzip 9.0
Should be OK now though.
Tried again later and both were the same.  Is it possible that I linked to different servers which had different files?? Noticed that dir.mnu in the win32filieio directory has different time stamp for the two.
(7,534 Views)
Hi Phil,
I'm not sure what could have happened there.  Perhaps one of the browsers already had an older version of the file cached and was just referencing it rather than downloading it?  I'm glad you were able to get the correct file now though!
Andrew
(7,508 Views)
