NI TestStand
Unload modules function / wish
When you select the "Unlod modules" in the module, you have no result message: user can't know if modules were really unloaded or not.
You can see the situation with a sequence that load a .DLL extension is opened and has run: if you want to delete (or update) the DLL file windows prevent you to do. Make Unload, Windows sometimes still prevent you.
I've not found the real conditions to reproduce the situation but I think you should improve the user information with that Unload Modules function to shos, as ex, which modules have been really unloaded and which ones not.
(4,602 Views)
Accepted by R1M
If you have a suggestion to make TestStand better, you really should post it oven in the TestStand Idea Exchange.
(4,591 Views)
I knew a place was dedicated but I couldn't find it. Thanks for the tip.
(4,586 Views)
