Remove "all" unused variables with a single click
The sequence analyzer in TestStand-2012 gives warning on "potentially unsed variable". The issue is, I have to click each warning, go to the variable and delete it.
Is there any way to delete all the potentially unsed variables at once?
Best regards
Ricky
(2,665 Views)
(2,614 Views)
Hi annav,
your link provieds the solution where you have to double click each variable in the analyser.
This is a very suiteable feature to keep sequence(files) clean. I often use this feature! "Double Click" and "Entf".
And most times i thought i would be great to habe a button there that deletes just all !
In my opinion there is not such a feature implemented.
@Ricky
I encurage you to post this Idea here:
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
and give a feedback when it is done. One of the first kudo will come from me.
Juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
(2,605 Views)
Thanks Jürgen.
I have posted it there.
May be TestStand wants user to look at variable before removing it. But if a user knows what she/he is doing, then such a button will ease file cleaning.
In worst case "Undo" always works and most of us have files in SVN or similar and back-ups and versions.
(2,579 Views)
(2,572 Views)
