NI TestStand
add arrays
I have 2 Local Arrays in TestStand
Local1
1,2,3
10,20,30
Local2
9,8,7
90,80,70
I also have a Labview VI with a 1d Array input that is within a FOR loop (3 loops using Local INDEX)
Is there a way to index the 2 Arrays and add them in TestStand and pass the result to the Labview VI?
I thought it would be as easy as writing this expression on the input of the VI...
Locals.Local1[Locals.INDEX] + Locals.Locals2[0]
eg.      loop1--- add 1,10 to 9,90
           loop2 --- add 2,20 to 9,90
           loop3 --- add 3,30 to 9,90
I hope this makes sense
Chris
(3,993 Views)
Are these 2 dimensional arrays?
You could do Locals.Locals1[0][Locals.Index] + Locals.Locals1[1][Locals.Index]
You need 2 bracket sets to access a 2D array.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,983 Views)
Hi jigg,
Yes they are 2D Arrays that feed into a 1D array in Labview.
I guess what you have suggested would require the Labview Input to be a Numeric and not an Array.
I have attached an example to see if this can be done.
The answer in Labview I was expecting is as below...
Loop 1
[0] 10, [1] 100
Loop 2
[0] 11, [1] 110
Loop 3
[0] 12, [1] 120
Chris
(3,966 Views)
