NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Remove all unused variable in sequence file with single click
In order to keep file clean, sequence analyzer helps in finding "potentially unused variables". To delete such variables, each warning in sequence analyzer result has to be double clicked and then delete has to be pressed to finally remove that variable.
In many cases with large sequence file, there could be dozens of unused variables and in a single work-space there are dozens of .seq files.
Is it possible to provide a button or some option to remove all unused variables from a sequence file?
