NI Linux Real-Time Discussions
PXE Boot Linux RT for PXI
No problem. I'm glad to hear it worked out!
When you get a chance, please send me the updated script; e.g. a PR on github or attache it here. I'd like to incorporate your change. I imagine others using opkg/ipk installation will hit this issue as well.
Message 21 of 28
(1,938 Views)
I just added a line to the exclude section to not add the folder where my IT put the ipk files from the NI PXI Linux RT repo
/etc/opt/ - which he broke into NI and another folder.
We have disconnected systems, so in order to make sure I had all the IPK available from the NI REPO in case I wanted to install something, he loaded every .ipk from the repo into the /etc/opt/ folder - a practice most (maybe?) would not do when commissioning a Linux system.  I am guessing on that part.  But it was of course very large almost 2.5GB worth of packages.
I can upload the modified .sh on my fork of your repo, and post it here.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 22 of 28
(1,933 Views)
Oh, I see, you have an offline feed. There's no standard path which we can blacklist. I thought you removed some standard cache directory that got bloated on your system.
I added a blacklist option to the script ( -b ) allowing users to specify files/dirs to exclude. Might be useful here.
https://github.com/harisokanovic/nilrt-net-boot/blob/ddacb204eefa8518120ee783ef9bf4d016dbf5ca/nilrt-...
Message 23 of 28
(1,923 Views)
Ah yes, that works nicely without having to edit the .sh itself
Message 24 of 28
(1,912 Views)
Tried to build a new netboot image with the -b option and ran into an error.
I posted an issue on the Github repo with screenshot.
Message 25 of 28
(1,904 Views)
Just to update the thread to make sure everyone knows - the Github code is working, the -b blacklist option is fully working.
I have a working Netboot process with my PXIe-8840QC that uses the image created to load from my tftp /dhcp server.  The option to utilize an nfs image as the boot is not natively supported by the NI Kernel, but could be enabled on a custom build of the kernel.  I am not sure I want to go down that path just yet of a custom kernel build, as I am not a Linux expert.
Message 26 of 28
(1,857 Views)
I want to change my NI PXIe 8840 QC from windows to Linux RT.
Now the PXI is into Linux safemode.
But when I formdisk form MAX, the MAX crashed.
If you have did this change?
Message 27 of 28
(1,761 Views)
@AmilyChen It sounds like you need to follow the process documented here:
Provisioning a PXI Controller to the NI Linux Real-Time Operating System
David C
Message 28 of 28
(1,744 Views)
