NI Linux Real-Time Discussions
Connecting RTOS to Windows via Samba
I am trying to set up a Samba share with a Windows 10 desktop. I set up the sharing in Windows and created the mount on the RTOS, and have tried mounting the share using
mount -t cifs //<IP ADDR>/data -o user=<username>,password=<password> /mnt/data
but I get
mount error(112): Host is down
This lead me to think that it is related to this issue. However, when I try to set the version with anything other than 1.0 I get
mount error(22): Invalid argument
I have successfully connected from Ubuntu so it appears to be a problem on the RTOS side. I also tried uninstalling cifs-utils with opkg and building from source but now I get
mount error: Server abruptly closed the connection.
This can happen if the server does not support the SMB version you are trying to use.
The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
I get the the same error even if I use vers=1.0 and I still get an invalid argument error with any other version.
If anyone has any suggestions I would be very appreciative.
Eric V.
(4,118 Views)
Accepted by topic author evanhorn
This thread might or might not help you. It gives some details, at least.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(4,082 Views)
Thanks, while not what I was hoping for, it does answer my question.
(4,041 Views)
