Hi Taggart,
It looks like this thread has been inactive for some time now. Could you post your question as a new thread in this forum? It'll likely get more attention that way, and will be more likely to get an answer.
Thought I'd replied to this already. We did get the right information. I'm away from my office this week but will try and dig it out and post it on here for you.
Paul
that would be awesome! Thank you.
Attached is the schematic for the P7000-UMI cable. The labelled items are as follows:
- P1 refers to the 26 pin connector
- P2 refers to the 15 pin connector
- 3 refers to a Transistor, DTA144ESA, Digital PNP, SC-72
- 4 refers to a Transistor, DTC144ESA, Digital NPN, SC-72
Hope that helps.
Thank you.
Hi Psmorris,
In the given schematic diagram, can I use normal NPN/PNP Transistors instead of the Transistor, DTA144ESA, Digital PNP, SC-72.
I have seen the datasheet of DTA144ESA, but still.
Thanks in advance!!!
Hola
Sé que la conversación comenzó hace mucho tiempo, pero me gustaría saber si podría conectar el módulo 9512 con el Drive P70360 ... Actualmente tengo la misma pregunta.
Gracias
Hola!
Te recomiendo que inicies un nuevo post con la pregunta. Las conversaciones viejas no tienen tanta exposicion y es mas dificil obtener respuesta de la comunicdad.
Por otro lado, este documento tiene los pasos para conectar un NI-9512 a un drive de ta serie P70000
Espero que te sea util!
