P7000 direct connect cable pinout help please
Hi Taggart,
It looks like this thread has been inactive for some time now. Could you post your question as a new thread in this forum? It'll likely get more attention that way, and will be more likely to get an answer.
Message 11 of 18
(2,056 Views)
Thought I'd replied to this already. We did get the right information. I'm away from my office this week but will try and dig it out and post it on here for you.
Paul
Message 12 of 18
(2,053 Views)
that would be awesome!  Thank you.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 13 of 18
(2,048 Views)
Attached is the schematic for the P7000-UMI cable. The labelled items are as follows:
- P1 refers to the 26 pin connector
- P2 refers to the 15 pin connector
- 3 refers to a Transistor, DTA144ESA, Digital PNP, SC-72
- 4 refers to a Transistor, DTC144ESA, Digital NPN, SC-72
Hope that helps.
Message 14 of 18
(2,028 Views)
Thank you.
Sam Taggart
GCentral
Message 15 of 18
(1,940 Views)
Hi Psmorris,
In the given schematic diagram, can I use normal NPN/PNP Transistors instead of the Transistor, DTA144ESA, Digital PNP, SC-72.
I have seen the datasheet of DTA144ESA, but still.
Thanks in advance!!!
Message 16 of 18
(1,603 Views)
Hola
Sé que la conversación comenzó hace mucho tiempo, pero me gustaría saber si podría conectar el módulo 9512 con el Drive P70360 ... Actualmente tengo la misma pregunta.
Gracias
Message 17 of 18
(1,492 Views)
Hola!
Te recomiendo que inicies un nuevo post con la pregunta. Las conversaciones viejas no tienen tanta exposicion y es mas dificil obtener respuesta de la comunicdad.
Por otro lado, este documento tiene los pasos para conectar un NI-9512 a un drive de ta serie P70000
Espero que te sea util!
Message 18 of 18
(1,479 Views)
