opcua 2017 BadWriteNotSupported
i cannt  write data in opcua 2017 client  and  see this error
by labview 2016 i write data easily
and with other opcua client i can write data
hep me please
Message 1 of 14
(6,885 Views)
If it works in LabVIEW 2016, but not in LabVIEW 2017, I have two (three?) suggestions:
  • Use LabVIEW 2016.
  • Wait until LabVIEW 2017 SP1 is released, then try that.
  • Wait until LabVIEW 2018 is released, then try that.
I'm really hopeful that you will not need to use the third solution.
Message 2 of 14
(6,856 Views)
Is LabVIEW 2016 allowed through the firewall and LabVIEW 2017 blocked?
Message 3 of 14
(6,851 Views)
1. You can use the Forward Browse.vi to get the information of the node. In the browse result, what is the node type?
2. What is the OPC UA server? Is it a 3rd-party server?
Thanks!
Message 4 of 14
(6,841 Views)
1-all things is ok except write data
2-yes server is twincat opc server but in labview 2016 and uaexpert opc client all things is ok
you can see attach files
Message 5 of 14
(6,833 Views)
You can use the Forward Browse.vi to know what is the node type of the assigned node as follow.
 The status "Bad_WriteNotSupported" is often caused by the node type is unsupported. So we'd like to know the node type.
Thanks!
Message 6 of 14
(6,809 Views)
i do it
and attach file
Message 7 of 14
(6,800 Views)
all windows  firewalls is turn off
Message 8 of 14
(6,792 Views)
Is it possible to reproduce this phenomenon on my side?
Thanks!
Message 9 of 14
(6,780 Views)
HI, I have the same problem... LabVIEW 2016 can write the tag, while 2017 cannot, with the same BadWriteNotSupported error.
The firewall is disabled, and the result of the Forward Browse for the given tag is:
reference type: Organizes
node ID: ns=2;s=iTestAliases.Pippo
browse name: Pippo
node class: variable
node type: DataItemType
Thank you for helping!
Message 10 of 14
(6,732 Views)
