gaussian fit
hi
I want to use gaussian curve fit on attached data.
Message 1 of 11
(5,573 Views)
Hi bijal,
ok. And what is your problem?
This is how your data look after some simple retreatment:
Message 2 of 11
(5,569 Views)
hi
when i use gaussian fit , i found result as per shown in fig.i got only the curve  peak fit.i want to fitt the graph using curve fit.Untitled.png
Message 3 of 11
(5,562 Views)
Accepted by topic author bijal
Hi bijal,
So you already found your result…
It already did a fitting to the data. What else do you expect?
It would help to see the expected result to know what you really want to achieve!
And please crop the image next time before attaching here…
Message 4 of 11
(5,558 Views)
can i smooth data with any other curve fitting method without changing shape of curve?
Message 5 of 11
(5,550 Views)
Hi bijal,
you want to keep the shape of the fitted curve even with smoothed data? Changing the data will change the fitted curve…
Please attach an example with real data and with expected result!
Message 6 of 11
(5,545 Views)
hi
i send real data of the x-y graph. when i plot this graph , it shows noise in graph . so i want to smooth graph .
Message 7 of 11
(5,541 Views)
Hi bijal,
that is the same data file as before…
Message 8 of 11
(5,539 Views)
i want to result like as per shown in fig below.
Message 9 of 11
(5,533 Views)
Hi bijal,
those data look very different from the one in your attached XLS file.
As said before: attach a VI with real data!
If it's just about the smoothing of the data: you may try to use PtByPtMean to implement a low pass filter using a running average…
Message 10 of 11
(5,529 Views)
