Vision Application built into a VI doesn't work when made into a executable
Hello Everyone,
I am used NI Vision Assistant to build a LabVIEW to perform pattern matching and OCR. I used the Vision Assistants "Build a VI" to create a VI. I then inserted that into my main program as well as the project that I am using. I then built an executable to test the program out on my main work station and the program doesn't seem to be doing anything past removing a color plane. I tried injecting the vision code in its raw state rather than as a SubVI and I still run into the same issue. Has anyone ran into the issue before? I've attached the VIs in question.
Dan
Message 1 of 9
(2,703 Views)
error codes, if any?
for starters, all image same type?
for vision that uses references, some serialization may help
CY (expired CLAD)
Message 2 of 9
(2,685 Views)
Hey Cy,
To answer your questions:
I don't get any errors when I run the program as a normal .VI, but when I run it as an .EXE I get the following error code:
-1074396157
Source:
IMAQ Setup Match Geometric Pattern 2
I think that error code is just a general error code, but I am not entirely sure.
Image types don't change throughout the program.
Dan
Message 3 of 9
(2,674 Views)
Accepted by topic author drogers13
Sounds like you don't have or have not activated the needed Vision Run-Time license.
-AK2DM
Message 4 of 9
(2,641 Views)
Hey AK2DM,
I am building and running the program on my workstation which has the Vision Development Module Runtime program installed.
Looking at the program, there are 2 "IMAQ Setup Match Geometric Pattern 2", where the error is being generated from. Both of those are "Call Library Function" nodes which I assume are built when in the Vision Assistant. The library they are calling to is located on the dependency list of the LabVIEW project. I am wondering if it isn't calling the library correctly because in the application because it has a different build path? I will try setting the build path into the same folder as the main program.
Dan
Message 5 of 9
(2,638 Views)
The error code is very clear, as was explained earlier.  This is what I get when I plug it into "explain error":
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(2,610 Views)
*sigh* Thanks, I'm not sure why it is giving me that error when I run the application on my main work station, but I assume it is something silly that won't take much to solve.
Dan
Message 7 of 9
(2,600 Views)
Use NI License Manager to verify it is activated.
-AK2DM
Message 8 of 9
(2,590 Views)
Hey AK2DM,
That was the problem. For some reason the Run-Time Engine was not activated when I activated the development module. I got it activated and everything is working smoothly now.
Thanks for you help,
Dan
Message 9 of 9
(2,582 Views)
