VI documentation
1.In a new VI(named it as label),added a case structure with Error In,out.
2.In No Error case,added whole my Proj Vi
3.Added all I/Os in connector pane
4.Ctrl+Space,Ctrl+C
5.There was some action but i did not see any docu generated.
Message 21 of 26
(1,773 Views)
Hi Krupa,
In a new VI (named it as label), added a case structure with Error In, out.
You must add your label into error case structure sub diagram label.
Did you install this version (build 12)?
https://decibel.ni.com/content/docs/DOC-46663
The previous version had dependencies from one other package.
The build 12 only use native LabVIEW VI.
If it still doesn’t work, could you send me you VI? I'll try it on my computer.
Regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 22 of 26
(1,744 Views)
The link you have shared is not visible for me.Its better i share my Vi with you as i still have the same issue.
I am using LV 2015,VIPM as well.Let me know if i need any thing more.
Could yuo pls share your email id,so i can send my code.
Message 23 of 26
(1,727 Views)
send you an email
Message 24 of 26
(1,717 Views)
Hi Krupa,
I open one of you subVI and do the ctrl+space then crtl+c and it worked well.
But you didn't write anythig into the subdiagram label of your error case structure.
I send you the last update of the package. Please install it and try it on the join VI.
Regards.
Message 25 of 26
(1,709 Views)
I have sent an email to your personal mail id,please kindly check.
Message 26 of 26
(1,699 Views)
