Where is the MUltisim design?
hello everyone
Recently I'm learning to study how to implement the multisim and labview combined simulation. Mainly to multisim import labview, I mentioned in attachment by ni company operation, installation labview2013, control module and simulation cycle. To install multisim12.0. Selected two plug-ins are installed together. But when I use the labview, the simulation - exeteral models mode not multisim - multisim - the design is optional. I tried to install two software connection tools are useless.Where is the MUltisim design?How to use labview multisim connection tool, can be used to joint the simulation? Can you give a tutorial.
who can help me
(3,609 Views)
Have you looked at the following presentation? You can probably get away with skipping to the middle for the bits you're after.
http://www.ni.com/swf/presentation/us/ewb/idat/
Tom
(3,456 Views)
if you install it it correctly you can go to all program and then national interments and find it there if you could not find it there it shows that you do not install it correctly
(3,440 Views)
Correct,
Use the following link to install Multisim, if it is already installed then it will tell you (and repair any damaged files).
http://www.ni.com/multisim/try/
(3,433 Views)
