Sharing a VISA refnum between two while loops.
Dear Ben and Jeff! I do not want to argue over trifles. I have been working with Labview since 1998 🙂 And I am well aware of most methods of building projects. If the questioner does not know the basics of building a project in a Labview environment, you should not complicate learning.
Labview 4.0, 5.0, 6.1, 8.6, 2009, 2011, 2012, 2014
If you do not know something, ask me.
Message 21 of 26
(1,111 Views)
@Ben wrote:
@Borjomy wrote:
If the project is small, then it makes no sense to equip the library. This is an extra work. The main thing is that the exchange with devices connected to one VISA device should be done in one VI
All projects start small. What Jeff was suggesting is a Best Practice that I agree with strongly.
Thank you,
Ben
In parable form
You'd be surprised how many times you can re-use those simple libraries. Or create one from a CUSTOM Project Template that needs only minor changes.
"Should be" isn't "Is" -Jay
Message 22 of 26
(1,107 Views)
Spoiler
OK, I'll trust you on that one. Smiley Wink
Ben
Message 23 of 26
(1,100 Views)
It all depends on how much the same projects and equipment used. If the project is large and long, there is absolutely no point in doing the Template in order to reuse it. Easier to copy. If there are differences (and they will certainly be), then it will have to be re-written. Especially for a beginner. This code will be rewritten ten times before it takes shape. And generally speaking. Topicstarter most likely communicates with devices on Modbus Serial, we just need to offer him the appropriate library so that he does not invent a bicycle.
NI-MODBUS-Library 1.2.1
Message 24 of 26
(1,099 Views)
That means nothing.  I have worked with several people who have been working with LabVIEW for a very long time and they are horrible coders (one even refuses to use an Event Structure).
Telling people to ignore best practices is just a bad thing.  I understand wanting to try to shield newbies from a lot of details, but they at least need to have the ideas in their head to think about with the next project.
GCentral
Message 25 of 26
(1,079 Views)
Thanks for all your input. I think it is an interesting discussion. However, personally I think the more information you can get the better. I'll just filter it for the most relevant information. This means it might not be applicable at this moment, but next time one may remember "Wait, the guys from the forum told something about libraries" . Which makes you dig into the NI information and forum topics about the topic.
Again, thank you all
Message 26 of 26
(1,065 Views)
