Send email on labview using the Gmail Server (TLS)
smercurio_fc wrote:
Here you go.
Very nice example!  By the way, you should make sure to close all the .Net references that are opened, or you will consume (leak) lots of memory.
Cheers,
-Jim
Message 11 of 114
(7,332 Views)
Just to make sure: I didn't write the example. I just resaved it as 8.2 as the user requested. Smiley Wink
Message 12 of 114
(7,312 Views)
Thank you for your example, but I got an error.
Did I forgot something?
Message 13 of 114
(7,299 Views)
That looks like a DNS problem at your end. What happens if you try to "ping smtp.gmail.com" at a command line prompt?
Message 14 of 114
(7,282 Views)
Noted 😉
Message 15 of 114
(7,280 Views)
Would somebody please save this in Labview 7.1 format? I'm very interested to play with it.
I'm limited as my company is not ready to upgrade my licence at this time
Thank you!
Message 16 of 114
(7,258 Views)
Here's a screenshot of the code.
Ton
My LabVIEW Ideas
Message 17 of 114
(7,241 Views)
Here it is in LabVIEW 7.1. Enjoy!! Great code by the way. Smiley Happy
Message 18 of 114
(7,207 Views)
Fantastic -thanks a million. This is very useful code!
Message 19 of 114
(7,184 Views)
When I use this VI and attach a LabVIEW generated text file to the email, when I try to write to the text file again (In LabVIEW), it is reporting that the file is already open. Error 5.
I then added code to this VI that would send a screenshot via Gmail. When I save the screenshot as a JPG and then attach it to the gmail, the same Error 5 occurs (file apready open) when I try to delete the JPG. Something is not being closed.....
Any clues to what this could be? I was wondering if it had to do with the NET references not being closed as someone else had stated earlier in this thread.
thanks.
Message Edited by tca-adam on 12-01-2008 11:45 AM
Message 20 of 114
(7,064 Views)
