Rotary table WEISS Labview
Is there someone out there with some experience sending commands via Modbus to a rotary table WEISS.
Message 1 of 23
(3,137 Views)
A picture doesn't give us much information to help you answer your question.  Does the company have a LabVIEW driver?  Do you have a detailed manual that describes how to control this "Rotary table WEISS" (model number not provided)?  Have you contacted WEISS?
Message 2 of 23
(3,087 Views)
are you looking to hire or seeking guidance?
Are you familiar with using the Modbus library in LabVIEW?
Santhosh
Soliton Technologies
Message 3 of 23
(3,076 Views)
I am looking for guidance. I have used the modbus library in Labview. I have not contacted the company yet. I will have a look to see if they provide a driver.
Message 4 of 23
(3,051 Views)
The documentation available from their website doesn't even tell anything about how to interface to that drive. What makes you think you can/need to use Modbus?
Rolf Kalbermatter  My Blog
Message 5 of 23
(3,029 Views)
Their documentation mention Modbus communication. I have succeeded using python but not with only the Labview blocks.
Message 6 of 23
(3,010 Views)
If you could share your Python code, it is possible to reproduce it in LabVIEW equivalent or in the worst case, use the Python code as such.
Santhosh
Message 7 of 23
(2,996 Views)
@santo_13 wrote:
...in the worst case, use the Python code as such.
lol, terrible option for sure.
But seriously op, post the python code.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 8 of 23
(2,959 Views)
Accepted by henk1000
That's the answer from WEISS
As I suspected, we cannot help you.
Unfortunately, we do not have anyone who knows anything about programming with LabView.
I cannot give you any further references either, as we have not come across this topic before.
Message 9 of 23
(2,941 Views)
This is not a solution definitely. If you succeded with Python, you can certainly do the same with the LabVIEW library. The matter is to use the proper functions with the proper arguments (addresses, for example, may not match).
Again, post your Python code and whatever you came up with LabVIEW describing what works (if any) and what doesn't.
Paolo
Message 10 of 23
(2,930 Views)
