Rotary table WEISS Labview
That is the Python code. It works for me. I have tried 3 libraries of Modbus in Labview including the NI Modbus library. Tried writing to single registers, multiple registers, coils, etc. Device number, time out, address, etc.
Always comes with an error when Labview executes the block to read.
Message 11 of 23
(1,643 Views)
So please post the NI Modbus free library version and describe which error and where, so we can check it.
Paolo
Message 12 of 23
(1,633 Views)
Seems pretty simple enough, please attach your LV code to see what could be the problem.
from pymodbus.client import ModbusTcpClient
def read_modbus(client, a, b):
    """A dummy docstring."""
    v = client.read_holding_registers(a,b).registers
    position = hex_to_dec(v[0], v[1], 10000)
    speed = hex_to_dec(v[4], v[5], 10000)
    torque = hex_to_dec(v[8], v[9], 1000)
    motor_state = v[12]
    print(f"position: {position}")
    print(f"speed: {speed}")
    print(f"torque: {torque}")
    print(f"motor_state: {motor_state}")
def hex_to_dec(reg1, reg2, factor):
    a = str(hex(reg1))
    a = a[2:]
    b = hex(reg2)
    b = b[2:]
    c = "0x" + b + a
    c = int(c, 16) / factor  # normaly 10000
    return c
def writeModbus(client, a, b):
    try:
        write_to_motor = client.write_registers(a, b)
        assert not write_to_motor.isError()
    except ConnectionError as errorcom:
        raise SystemExit from errorcom
def modBus():
    try:
        client = ModbusTcpClient('192.168.1.200', port=502)
        print("Modbus connected")
        print("Can not connect to PLC!")
    return client
connect = modBus()
read_modbus(connect, 60, 13) # Read from 60, 13 registers
writeModbus(connect, 0, 1)   # Write on register 0, value 1
connect.close()
Santhosh
Soliton Technologies
Message 13 of 23
(1,623 Views)
Well if you are having so much trouble with the LabVIEW modbus libs and the Python modbus lib works, just call the python code in LabVIEW with a python node, see here in LabVIEW for examples:
 Examples for using the Python Node are available in the LabVIEW Example Finder (found in Help >> Find Examples...) under Communicating with External Applications >> Using External Code >> Integrating Python Code.
Or if you must make it work in pure LabVIEW, post the error that you got.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 14 of 23
(1,622 Views)
Ask them for the MODBUS protocol.
Message 15 of 23
(1,611 Views)
That's what I have been doing, but would nice having only the Labview application.
Message 16 of 23
(1,581 Views)
Message 17 of 23
(1,578 Views)
@henk1000 wrote:
Thanks, that helps. Error 56 is a timeout error:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Lz2SAE&l=en-US
Message 18 of 23
(1,564 Views)
I don't have that modbus library, can you set the timeout?
Message 19 of 23
(1,563 Views)
What happens if you try this ?
Message 20 of 23
(1,554 Views)
