Regular expression != regular expression?
Hello all!
Both VIs are supposed to find the same string part.
Both search inputs are labeled "Regular expression".
Why not as expected?
Message 1 of 14
(5,967 Views)
Accepted by MaSta
It's about the function name (those are functions, not VIs).
The top one is actually "Match Pattern", the bottom one is "Match Regular Expression".
"Match Pattern" was added decades ago. Back then the input name "regular expression" was probably as good as any. It still is a valid name on it's own, just not in the context as we know it now.
"regular expression" is now tightly linked to the PCRE library (mostly compatibly with "Match Regular Expression"). But there's no rule "regular expression" has to be a PCRE expression. It's just an expression that is, well, regular. And the match pattern function does expect an expression that is regular.
Message 2 of 14
(5,965 Views)
I suspected something like this. The match pattern function sort of can do regex, but not all. In the end it's a irritatingly named input.
Message 3 of 14
(5,936 Views)
To complete what Wiebe said, the help of "Match Pattern" says:
"The Match Pattern function is compatible with a limited set of regular expressions and does not support character grouping, alternate pattern matching, backreferences, or non-greedy quantification."
So it is a regular expression, but with fewer options than with function "Match Regular Expression".
Raphaël.
Message 4 of 14
(5,930 Views)
Raphaël.
I always thought of it as "regex lite".
Bill
CLD
(Mid-Level minion.)
Message 6 of 14
(5,883 Views)
Raphaël.
"regex too lite" for me 😁.
Message 7 of 14
(5,867 Views)
Raphaël.
That's a better description.  I actually never use this for that reason.  It's either "too complicated" or "not complicated enough" for what I need it to do.
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(5,852 Views)
Quite a bit slower though. When Match Pattern is enough it's the much preferred alternative.
This simple test, 100k characters random from ascii 32 - 132 and turned into a constant, then filtered as you can see, takes 6 vs 75 ms!
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 14
(5,789 Views)
often, I use  the regex modus of the function "search and replace string" instead of match pattern.
If you want to search for more complex patterns, such as patterns that contain character grouping, alternate pattern matching, backreferences, or non-greedy quantification, configure the function for advanced regular expression searches or use the Match Regular Expression function.
Message 10 of 14
(5,772 Views)
