Regular expression != regular expression?
@alexderjuengere wrote:
often, I use  the regex modus of the function "search and replace string" instead of match pattern.
I did a quick test and switching that on or off is very similar to Match pattern/Regular expression in speed. It seemed to be slightly faster as you only create one output.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(22,180 Views)
I still use the Match Pattern function regularly. It’s already complex enough that I have to consult the context help anyhow but not as complex as PCRE which usually creates a knot or two in my brain cells. And there is a performance advantage too: The PCRE function is generally slower.
As it is also said: I had a problem and used PCRE to solve it. Now I have two problems!
Rolf Kalbermatter  My Blog
Message 12 of 14
(22,180 Views)
Additional note on the different between these two:
"Match regular expression" is actually an Xnode.
Darren has a post with a video posted here, in which it is explained that use of Xnodes is on occasion the cause of some weird LabVIEW problems (the section on Xnodes starts a little bit after 10 minutes in).
As such, if you do need to match a regular expression that isn't usable with the "Match Pattern" limited inputs, instead of using the built-in "Match regular expression", you can use this VI instead without the need for an Xnode:
\vi.lib\regexp\Match Regular Expression_Execute.vi
It returns the values found as an array instead of as individual outputs on a resized "Match regular expression" node, but is otherwise a completely equivalent function call with less overhead and does not invoke an Xnode.
Message 13 of 14
(22,146 Views)
Sounds like they implemented this idea (although it's in LV13, and the idea is 2017 😋😞
Add Match Regular Expression sub VI - NI Community
My VI returns offsets too (of the 'goups' 🙄), and the implementation is a bit nicer, if I can say so myself...
A benefit of an XNode (any inlined code) is that dead code actually gets removed. So the wired inputs and outputs of the XNode can actually have an impact on performance.
Message 14 of 14
(22,071 Views)
