wiebe@CARYA
Allow replace with empty string in Text Search Results dialog
Status: New
It's kind of annoying that replacing text with an empty string is not allowed.
Let's say you have 50 controls, all formatted tagname_tagnumber. You want to rename them to just tagnummer (or just tagname).
Finding them all is easy (regex ^.*_).
Renaming them all to A_tagname is easy.
But renaming to just tagname is not allowed...
(I know I can use scripting...)
4 Comments
wiebe@CARYA
Knight of NI
Thanks for the 1st kudo,
Manzolli
This case you mentioned can be done by searching the whole word "tagname_tagnumber" then replacing for "tagnummer" or "tagname". But if you have "test-A", "test-B" and "test-C" and want to get rid of "test-" resulting in "A", "B" and "C" then you are right.
André Manzolli
Mechanical Engineer
LabVIEW Champion
Curitiba - PR - Brazil
wiebe@CARYA
Knight of NI
Not if tagname_tagnumber are regular expressions (I think)? That would require (expression A)_(expression B) to be replaced with $2, which is also not possible (yet, but unlikely to happen).
Anyway, regardless the use case, it's inconvenient you can't replace with an empty string.
Thanks for the kudo!
Petru_Tarabuta
+1. "Seems like a no brainer to me... Borderline bug." - fully agree. As another data point, I sometimes use the excellent PowerRename tool (part of the Windows PowerToys suite) to rename sets of files. That tool can replace with empty string, and is a feature that I used multiple times.
The following is a somewhat related idea: The Search Results window should contain a “Remove” button
