Real Time 3D Surface/Graph
I am trying to construct a 3D surface graph from incoming data from ultrasonic sensors using the myDAQ. I have currently created a randomly generated Z array with fixed X and Y values, however I am wondering how to create a more real time version of this graph by creating the inputs for the z coordinates when x is (0,0) and Y is (0,0) in increments of 1 point. I am a complete newbie to labview and even our university lecturer doesn't know how to use the software. I have uploaded the vi for the randomly generated 3d surface.
(4,146 Views)
I cannot open the VI as I don't have a new enough version of LabVIEW installed, but you could take a look at this post which might help:
https://forums.ni.com/t5/LabVIEW/XYZ-Surface-plot-on-the-go/m-p/3875355#M1098383
I am not sure what is meant by "reating the inputs for the z coordinates when x is (0,0) and Y is (0,0) in increments of 1 point" can you give some more detail.
0xDEAD
(4,139 Views)
Essentially my group and I are making a surface mapper and we want to record a specific Z coordinate when the sensor is in a specific place using a rocker/switch and then log each point of data to a set of X,Y coordinates so (0,0), (0,1),(0,2),(0,3)...(0,10) and then go back to (1,0),(1,1),(1,2)...(1,10) until we reach for example (10,10).
Unless there is an easier way of creating a real time surface map I'm unaware of?
(4,127 Views)
Accepted by serialcommunication
Sorry, I only just seen this reply. Hopefully the answer I posted in the other thread helps.
The X and Y coordinates you can pass in to the 3d surface graph as a 1D array of all X values and 1D array of Y values.
The Z heights you pass in as a 2D array of size (X by Y) of heights corresponding to the X and Y.
For example, plotting a flat plane of height 1 at X = 0,1,2 and Y=0,1,2
X is array
[0,1,2]
Y is array
[0,1,2]
Z is 2d array (3x3 in size)
[1,1,1]
[1,1,1]
[1,1,1]
To dynamically update values, you can start with the Z array as an array of NaN and replace them as you go along.
0xDEAD
(4,086 Views)
