03-29-2019 11:01 AM
Hi, im totally new to using the datalogger, i would be very thankful if someone could help.
Im looking to connect an amplifier transducer:
https://www.fylde.com/wp-content/uploads/2018/03/FE379TA.pdf
to the NI USB-6212. There is only a single output from the transducer (with a BC connection), i don't understand which input on the logger shouldi connect the wire to?
Thanks so much.
04-01-2019 09:51 PM
Find an engineer who can understand what the amplifier transducer does, what its output is (there's not a lot of information in the PDF you attached, but it does have a ±10v output, possibly over a BNC which I'm guessing is what you called a "BC Connection"). He (or she) might be able to explain what to do with the USB 6212 and how that has anything to do with "the datalogger".
