From 11:00 PM CDT Friday, Nov 8 - 2:30 PM CDT Saturday, Nov 9, ni.com will undergo system upgrades that may result in temporary service interruption.
01-19-2015 09:25 AM
Thank you everyone for your help.
After a call to B and B a solution was found. The problem was not in the code or the B and B hardware but was in the cabling. I was told by B and B tech support that if the loop back test worked then the likely problem was in the cable between the Instrument and the converter. In my application what was required was a null modem or cross over cable. Apparently the gyberish data that i was recieving is also an indicator of needing a different cable.
Dennis, sorry to have taken so much of your time and I greatly appreciate the help.
01-19-2015 09:28 AM
Thanks for closing the loop and getting back to us. The DCE port config is of course a difference from a PC's DTE port
01-19-2015 09:32 AM
Incase this forum is stumbled across in the future I should also mention that I needed to build a cross over cable between the cRIO and the B and B converter to cross over the Rx and Tx lines.
01-19-2015 09:34 AM
