RS-485 to RS-232
Thank you everyone for your help.
After a call to B and B a solution was found.  The problem was not in the code or the B and B hardware but was in the cabling.  I was told by B and B tech support that if the loop back test worked then the likely problem was in the cable between the Instrument and the converter.  In my application what was required was a null modem or cross over cable.  Apparently the gyberish data that i was recieving is also an indicator of needing a different cable.
Dennis, sorry to have taken so much of your time and I greatly appreciate the help.
Message 11 of 14
(775 Views)
Thanks for closing the loop and getting back to us.  The DCE port config is of course a difference from a PC's DTE port
"Should be" isn't "Is" -Jay
Message 12 of 14
(773 Views)
Incase this forum is stumbled across in the future I should also mention that I needed to build a cross over cable between the cRIO and the B and B converter to cross over the Rx and Tx lines.
Message 13 of 14
(766 Views)
Glad you got it working. I'm not sure how you could have received any data at all, though.
Message 14 of 14
(765 Views)
