Quick Drop Question
I've been using quick drop quite a bit lately.  I use the CTRL+space, CTRL+I to insert VIs into existing wires, but there are times were it's faster for me to drag VIs from the palette onto the block diagram.
Does anyone have a quick drop plugin that lets you select a VI and a wire and automatically wire them together?  For example it would be nice if I could select a VI with error terminals and the error wire and use quick drop to automatically wire them up.
(4,111 Views)
Accepted by topic author TomFantasia
(4,092 Views)
Thanks Todd.  I think I can modify that quick drop plugin to do what I'm looking for.
(4,069 Views)
Post it in the Quick Drop Community when you're done. Smiley Happy
Jim
(4,050 Views)
CTRL+SHIFT+I inserts into several wires, if you have them selected, where the ordinary ctrl+i would insert X amounts of the same object, where X is the number of wires selected.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,029 Views)
Here's what I came up with based on the suggested example:
https://decibel.ni.com/content/docs/DOC-30586
Tom
(4,002 Views)
