Plot the angular position of two motors
Hi, I would like to plot the angular position of two motors (X,Y) in a single graph. It means plotting the angular position of motor X along x-axis &  angular position of motor Y along y-axis in LabVIEW. Can anyone suggest me any VI, or how to implement it in LabVIEW.
Message 1 of 18
(4,452 Views)
-The XY graph accepts a cluster that contains an x array and a y array. Refer to the (X and Y arrays) Single Plot graph in the XY Graph VI in the labview\examples\general\graphs\gengraph.llb for an example of a graph that accepts this data type.
Ref more: https://www.ni.com/docs/en-US/bundle/labview/page/types-of-graphs-and-charts.html
uday
Message 2 of 18
(4,448 Views)
I have already gone through this link but couldnt find any solution. I want to know weather from the graph a list of array can be taken or not?
Message 3 of 18
(4,430 Views)
Could you explain a bit more?
-The array input which you provide to Y-axis of Two graphs have to be used as X-array and Y-array for the graph( This is what i understood from your question).
-Now, what do you mean by
uday
Message 4 of 18
(4,426 Views)
ok..let me explain. From motor X,  I can aquire its signal  by DAQ Assistant & display its angualr position in a graph, where I am plotting its angualr position w.r.t time. Similarly for motor Y. Now in my new graph I want to plot along x-axis..will be motor X position & motor Y position along y-axis. I have already attached a file peviously for yours simplicity.
Also you suggested to generate an array & cluster..so I asked that from where to generate array?
Message 5 of 18
(4,423 Views)
Did you look into the examples in that path?
-try an example and post VI or LabVIEW snippet.
uday
Message 6 of 18
(4,420 Views)
I have LabVIEW 11 version, & cannot find the link path provided by you.
Message 7 of 18
(4,415 Views)
Go to LabVIEW menu options-> Help->Find Examples-> Search for XY Graph
uday
Message 8 of 18
(4,411 Views)
If you are getting an array of X and Y values you can bundle and feed for XY Graph Node.
Message 9 of 18
(4,407 Views)
After aquiring the signal grom DAQ Assistant, I am getting the angular position of both the motors. This angular position is depicted both in numeric indicator & its corresponding graph. Now will I generate an array of X & Y values from this motors to be feed into bundle.
Message 10 of 18
(4,368 Views)
