Coding with a simple If else statement using text file values
Hi there Labview Professionals,
I have an issue with coding some simple if else statements using text file data.
As attached from the text file I have provided. (When you open the text file, there are 3 long columns of data, variables C G and D respectively.) I have to check the C and G values if they are larger than 0.65.... if one of the values are larger than 0.65, I have to increment a count and the boolean button would light up indicating there is one. The entire process continues throughout the data.
So far, I have only managed to create the if else statement with fixed numeric points. Does any of the professionals know how to replace the fixed numeric points through the text file?
Much appreciated!
Message 1 of 21
(4,697 Views)
I got a bit confused what you really want but
I think you have to work with In Range and Coerce Function vi
and also Boolean function
Message 2 of 21
(4,687 Views)
Apologies if its too confusing for you.
Basicially, when I load the data file, the if else statement will scan the 3 columns and check individually if any value is larger than 0.65, if it is larger than 0.65 I have to make a output stating that 1 of the data has a value larger than 0.65 for which I have to make use of the boolean button to act as some kind of "LED" to light up if there is a value larger than 0.65.
Only the third column is not affected by the if else statement and data will be continued to be read.
Message 3 of 21
(4,685 Views)
now what is your problem to solve?
Message 4 of 21
(4,677 Views)
I couldn't link the text file path to the entire if else statement.... am I short of something or what do I need to add it so that the text file data can be read and data can be scanned for values larger than 0.65?
Message 5 of 21
(4,667 Views)
Hi
I could not open your file since I am having LV2014. But from your ques i suppose you can open the text file and read the first 2 columns and compare whether its >0.65. i.e read first column and compare. then read second colum and compare.
Nghtcwrlr
Message 6 of 21
(4,657 Views)
How do you do this part? This is what I couldn't do. I have only managed to create the "greater than" portion....
Message 7 of 21
(4,653 Views)
Hi Lexen,
Trying to translate your text "word by word" into LabVIEW:
Read the file, index the columns, compare with your threshold value, "light" a boolean indicator, increment a "count"…
Message 8 of 21
(4,652 Views)
GerdW was a bit faster than me 😛
Nghtcwrlr
Message 9 of 21
(4,647 Views)
and also me 🙂
Message 10 of 21
(4,644 Views)
