Multiple polar plots into a 3d plot
Here are some images of teh plot from different views.
Ben
Message Edited by Ben on 09-24-2005 03:56 PM
Message 11 of 37
(8,241 Views)
Thanx for the reply...The elevation detector moves in an arc, where the distance between the source and the detector remains constant. A torus type 3d plot is what I am looking for.
Message 12 of 37
(8,202 Views)
Ben,
Thank you for your help...I will look at this closely. My detector moves in an arc, where the distance remains constant...for this reason I am looking for a "doughnut" type 3D plot.
Message 13 of 37
(8,203 Views)
"where the distance remains constant...for this reason I am looking for a "doughnut" type 3D plot."
It would have been nice to know that earlier. When I got the plot projections to match with your polar plots, I thought I had it.
Oh well...
When you get done fixing this, please post what it SHOULD have looked like.
Ben
Message 14 of 37
(8,199 Views)
Thank You,
I will post it when I am done
TA
Message 15 of 37
(8,190 Views)
Bump so support can find this thread.
Ben
Message 16 of 37
(6,237 Views)
bump so support can find
Message 17 of 37
(6,216 Views)
Hi Ben,
Can I suggest that you post this on the NI communities.  This is now a useful repository of example code and will save you having to bump it.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 18 of 37
(6,137 Views)
James McN wrote:
Hi Ben,
Sure you can suggest it but until I see a good tutorial on how to use that forum, it will have to wait. I just don't have time to investigate it myself and all of my request for tutoials on that furom have gone un-answered.
So...
"Tag you are it!"
Ben
Message 19 of 37
(6,132 Views)
Hello Ben,
I know this code is old but I have a question. I am not entirely sure how to correctly set up the colourmap/colour value vi.
You see, I have some data that varies from 400 to 2000. I want to set the maximum value of 2000 to dark red for example. However, the activex always seems to autoscale it and maps the maximum value in the data set to dark red. So for example, if the maximum in the data set is 1900, then those plots will be dark red.
How do I manually change this, as I have different sets of data, with different  mini and maxi values.
Cheers
Kamilan
Message 20 of 37
(5,767 Views)
