01-25-2013 07:44 AM
Thanks for this post. Will your instructions work for a LabVIEW 2009 error 3?
Best,
David Bowers
01-28-2013 02:31 AM
Hi David,
this will only work from LV 2011 SP1 or higher.
Cheers, RMathews
02-15-2013 02:44 PM
"Value added data." Is data that has been adjusted so that it add value (or gravitas) to the assumptions or statements that are made. Similar to a FACTOID, a non factual statement repeated enough times that it is believed to be a fact.
02-15-2013 07:10 PM
The error code 3, will destroy us.
02-26-2013 01:40 PM
I have the same problem but with LabVIEW 2012.
02-27-2013 04:22 AM
have you tried what is marked as solution of this thread?
Cheers
02-27-2013 08:13 AM
In LV2009 I installed the f3 patch and was able to load my VI. 🙂
db
02-27-2013 08:56 AM
I gave a try but no success.
I also applied the LV f3 patch. no success either.
I have no time to loose, so I re-developped it. I'm almost finish. but it not completely identical yet
02-28-2013 04:57 AM
sorry, but I also can fix your vi. I tried it as well. ![]()
Generally I can only recommend to make backups, so that you dont have to redevelop if anything goes wrong.
Bye, RMathews
02-28-2013 06:45 AM
My quote comes from Jon Stewart's reporting on the ClimateGate Scandal on his TV show. He quoted part of one of the intercepted emails. It said something about "tricks" used to "adjust" the climate temperature data to make it "value-added data". Fancy way of saying "massaged" data. Or in the case of ClimateGate data "fudged to make the data say what you want it to say." ![]()
