LabVIEW load error code 3: Could not load front panel
Thanks for this post.  Will your instructions work for a LabVIEW 2009 error 3?
Best,
David Bowers
Message 81 of 176
(2,853 Views)
Hi David,
this will only work from LV 2011 SP1 or higher.
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 82 of 176
(2,836 Views)
"Value added data."  Is data that has been adjusted so that it add value (or gravitas) to the assumptions or statements that are made.    Similar to a FACTOID, a non factual statement repeated enough times that it is believed to be a fact.
Message 83 of 176
(2,797 Views)
The error code 3, will destroy us.
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
Message 84 of 176
(2,779 Views)
I have the same problem but with LabVIEW 2012.
Message 85 of 176
(2,753 Views)
have you tried what is marked as solution of this thread?
Cheers
Ramona Lombardo
Message 86 of 176
(2,735 Views)
In LV2009 I installed the f3 patch and was able to load my VI. 🙂
db
Message 87 of 176
(2,728 Views)
I gave a try but no success.
I also applied the LV f3 patch. no success either.
I have no time to loose, so I re-developped it. I'm almost finish. but it not completely identical yet
Message 88 of 176
(2,717 Views)
sorry, but I also can fix your vi. I tried it as well. Smiley Sad
Generally I can only recommend to make backups, so that you dont have to redevelop if anything goes wrong.
Bye, RMathews
Ramona Lombardo
Message 89 of 176
(2,704 Views)
My quote comes from Jon Stewart's reporting on the ClimateGate Scandal on his TV show. He quoted part of one of the intercepted emails. It said something about "tricks" used to "adjust" the climate temperature data to make it "value-added data". Fancy way of saying "massaged" data. Or in the case of ClimateGate data "fudged to make the data say what you want it to say." Smiley Wink
PaulG.
Retired
Message 90 of 176
(2,695 Views)
