LabVIEW load error code 3: Could not load front panel
Hi, I was experiencing the same problem. I don't have SP1 installed. Could anyone be able to open the attached subVI and send it back to me at mdeng@ksr-tech.com I highly appreciate your help!
Message 71 of 176
(3,490 Views)
There you go!
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 72 of 176
(3,479 Views)
Why is this still creating errors in LV2012.03f? Is this a bug we are just going to have to live with? This is the kind of thing that I find really frustrating working with LabVIEW.
PaulG.
Retired
Message 73 of 176
(3,465 Views)
What makes you think that LV12 f3 caused this?
Message 74 of 176
(3,460 Views)
I didn't say 2012 caused this. This bug has been around since at least 2009.
PaulG.
Retired
Message 75 of 176
(3,449 Views)
But you said "why is this still creating errors in LV2012.03f?"
Nowhere in the poster's message did he say that it was LV 2012f3 that caused the corruption.
Message 76 of 176
(3,445 Views)
Hi All,
If anyone could help me with a similar issue: I did attempt the fix myself, but to no avail.
The problematic vi is “Aardvark I2C Pullup.vi” within aardvark.dll zipped and attached.
Gordon
Message 77 of 176
(3,403 Views)
Hi, I have experienced the same problem. I am trying to fix it as per your recommendation. You mention in step 3 to open the VI. I cannot even do that. I get the error message as soon as I try to open the file. Do you have any suggestions on how to circumvent the problem (e.g if there is any parameter I can add to the ini file to force the vi to open only its block diagram)?
Message 78 of 176
(3,374 Views)
@JeeEmm wrote:
Hi All,
The problematic vi is “Aardvark I2C Pullup.vi” within aardvark.dllLLB zipped and attached.
Gordon
Message 79 of 176
(3,354 Views)
HI JeeEmm,
I could not open your VI neither, although it was working with all the other ones. I guess it is really broken and cant be recovered at all.
DJ - I dont know any other tricks as the one mentioned here - important is, that you have at least LV 2011 SP1. In lower versions this will not work. So if you have a older version you can post the VI and I can try to fix it.
Sorry, for not being able to help.
Ramona Lombardo
Message 80 of 176
(3,347 Views)
