02-28-2013 08:11 AM
Thanks for giving a try RMathews.
I Re-developped the VI.
03-05-2013 01:43 AM
Dear Houssam,
I've done everything I can with with NI will allow me. With my lowly student edition though, I don't have a whole lot of pull, and my options are nill. If you could fix my file, I would be so grateful. I'd rather not ask/intrude, but at this point it's the only option I have.
Anyhow, I've attached the file that I've been unable to open. If you can help, that'd be great!
Carson
03-05-2013 02:23 AM
HI Carson,
I didnt had any problems to open your vi. I copied the blockdiagramm to a new one.
Generelly I think it would have been faster to reprogramm it at all as it is a quite small one
Here you have in the LV version 2010 as I didnt know which version you are using.
Cheers, RMathews
03-05-2013 02:28 AM
Ah Thank you so much. I realize it's not a very big VI, but I've not been using LabView long, and was afraid to try and reprogram it in 2011. Plus, a friend of mine couldn't get it working in 2012 or 2013, so I just wasn't sure. Either way, I sure appreciate you taking the time to fix it for me RMathews.
03-06-2013 01:58 AM
I'm having the same issue, though the aforementioned methods don't work (LV2012f3 Dev). Could someone fix this file please? Thanks very much in advance!
03-13-2013 07:58 AM
Hi RMathews,
Could you please send me your mail so I can send you my VI?
I'm also receiving the Error3 - error code.
I'm working with LabVIEW 2009 and tried the given solutions of this topic, but nothing works 😞
Thanks!
03-13-2013 09:25 AM
HI
Jeanuis, I couldnt fix your VI neither - sorry.
lderijck - for personal assistance please contact you local NI branch, or download the evaluation version of LabVIEW 2012 SP1 (http://www.ni.com/labview/) and try the solution posted in this forum post.
Cheers, RMathews
03-13-2013 01:21 PM
RM,
Tried submitting it, evidently there are header errors in the file that couldn't be fixed. Just ended up rewriting it, thanks for the attempt though!
04-24-2013 04:08 PM
I had this same issue. In my build Source File Settings I had to unclick the Use default save settings. Even though it looks like the remove from panel is not checked.... anyways this fixed the issue for me.
05-23-2013 02:53 AM
hi there, hi RMathews,
I couldn't imagine that such an error may occur and make a VI totally corrupted... And so, I know now that backup is highly recommended !
I tried the solution posted above (connPaneRecoveryMode=True), but I wasn't able to open my VI (on Labview 2012). I also downloaded the evaluation version of Labview 2012 on another PC, but it was also unsuccessful.
I would be very grateful if you could try to fix my VI ! It would save me a lot of time !
Thanks a lot !
Cheers, Olivier
