LabVIEW at 20!
To start a new thread, go to http://forums.ni.com/ni/board?board.id=170 and click on "New Message". then follow steps 1..3.
Since you use a diagram constant of 000107, I assume that this number is always exactly the same. Is it???
Attached are two possibilities (LabVIEW 7.0).  There are many other ways to do this...
Mod1 is more similar to your attempt, it just replaces all undesired elements with nothing. First we remove ALL "\r\n000107", then all spaces, then all "\r\n". Notice that you need to wire a TRUE to the "replace all?" terminal, or it will only replace the fist instance of the search term.
Mod2 is one alternative approach.
Try to understand both examples. 😉
Message 151 of 176
(4,228 Views)
Can somebody arrange me a Labview 1 copy?
Message 152 of 176
(4,195 Views)
Waow.... A LabVIEW 1 copy !!! Smiley Surprised
What for ? Just for the fun of having it ? You ll need on old MacIntosch to run it... I ll talk to my people to see if they can get that antiquity from the museum...
Epictetus
Antoine Chalons
Message 153 of 176
(4,189 Views)
I have LV 1.2 saved as OS X disk images. If that is of interest, let me know.
NI had version 1.0 running on a Mac SE at NIWeek. They had a competition to see who could put together a simple VI most quickly. I tried but at least one other person was faster than I was.
Lynn
Message 154 of 176
(4,169 Views)
Just received the new issue of the Instrumentation Newsletter. There's a neat little image of a block diagram on the cover showing a bit of code from 1986 LabVIEW feeding another bit of code representing 2006 LabVIEW.
I'll take the 1986 any day. That's LabVIEW!  The 2006 version is "programming by dialog box".
I must confess I've tried a few of these Express thingys, but quickly adbandoned them.
BUT..... they do have a very important use. A lot of them can be "viewed as an" icon and then converted so the block diagram can be opened. You can then study the code and learn a few tricks.
Message 155 of 176
(4,159 Views)
If you look closely at the code illustrated on the cover of "Instrumentaion Newsletter" (third qtr 2006) that can be found here
http://www.ni.com/news/inst_news_q3_06.htm
you will see an inverter on the lower input of the add node. See this inamge.
In what version did we loose this feature?
Ben
PS I know I can do that with the compound arith...
Message Edited by Ben on 08-16-2006 10:49 AM
Message 156 of 176
(4,144 Views)
What feature? 😄
Message Edited by altenbach on 08-16-2006 08:47 AM
Message 157 of 176
(4,136 Views)
Hi All,
I the first labview I used was LabVIEW 3 (1996) but first app was done in LV4. But I think the best upgrade was when undo was added LV 5 first time if I remember correctly God Sent.
Message 158 of 176
(4,089 Views)
I NEED MAKE A CHRONOMETER WITH MULTI TIMES AND MULTI LAPS, THE DATA SHOULD BE STORED IN DIFFERENT DISPLAYS, THEY WOULD BE FOUR IN TOTAL
THANKS
Message 159 of 176
(4,063 Views)
Hi Pipelon,
Sorry to inform you that this particular thread has to do with reminicing Labview over the past 20 years.
Please post your quetion in a new thread.
You can do that here: http://forums.ni.com/ni/board?board.id=170
and simply click on "Newe Message" near the top left.
or better... try this link:  http://forums.ni.com/ni/board/post?message.subject=&board.id=170
Altenbach,
Nice image for Ben..
Message Edited by JoeLabView on 08-17-2006 02:50 PM
Message Edited by JoeLabView on 08-17-2006 02:53 PM
Message 160 of 176
(4,053 Views)
