How to catch an event when USB device is plug-ed / unplug-ed?
I want to register for an event that is generated when user unplugs / plugs USB device into PC. I saw solutions in other languages like Delphi and C++ but cannot find a way in Labview...
I don't want to check for devices in a loop, I want to have event generated automatically when this happens.
(4,372 Views)
I suspect you will need to use a .NET event that calls a callback VI and have that VI send a user event to your events case.
I would start with this Stackoverflow thread:
https://stackoverflow.com/questions/26975946/detecting-usb-device-insertion-and-removal-in-c-sharp
And try to implement roughly what that person did in, but in LabVIEW using .NET nodes.
This is likely the .NET class to use:
https://learn.microsoft.com/en-us/dotnet/api/system.management.managementeventwatcher?view=netframew...
(4,359 Views)
Any other hint or maybe even VI that does this?
(4,352 Views)
You'd have to fiddle a bit with the 'e' object to get useful info, but it's a start...
(4,293 Views)
What about continuously checking visa find resource results for changes?
(4,284 Views)
Thank you, but could you please save this two VIs in 2019 version? Thanks very much
(4,226 Views)
Thanks  wiebe@CARYA for the soultion, i was trying something similar but your solution works fine.
(4,175 Views)
