How can I write a sum formula in LabView? Help!!
Dear lovely GerdW,
Everybody says do it. just do. DO! do! Do!
Nobody here is kind enough to say how I can do it.So I wrote this forum.
I have just started an intern. I didnt find any tutorial video about histogram example.
kind regards.
Message 21 of 24
(1,232 Views)
Hi Anni,
Several items:
- LabVIEW help
- www.learnni.com
- all the training links for LabVIEW beginners in the header of the LabVIEW board
Take your time to learn LabVIEW before you start coding…
Message 22 of 24
(1,228 Views)
Did you look in the example finder for histogram?  The example finder usage should be covered in the tutorials.  Searching u-tube is not the ideal thing to do .
"Should be" isn't "Is" -Jay
Message 23 of 24
(1,204 Views)
@GerdW wrote:
Hi Anni,
how do you divide two sum formulas`?
Look carefully at that CompoundMath node…
that's actually hard to spot
this little blob means "invert" (right click), the inversion of summation (+) is subtraktion, the inversion of multiplication (x) is ...?
Message 24 of 24
(1,022 Views)
