error loading lvanlys.dll in Labview 64 bits
I have installed labview 2019 64 bits in a new computer with a AMD Ryzen 3800x cpu. I get the error loeading lvanlys.dll whenever this dll is called (the dll is in its folder and the installation was default). If I run Labview 32 there is no such problem, but I need Labview 64 to have access to more memory.
In other computers also with Labview 64bits and intel cpu I do not get such error.
Is there any solution to be able to use Labview 64 bits?
Message 1 of 33
(13,189 Views)
What operating system and version are you using?
Tim
GHSP
Message 2 of 33
(13,176 Views)
Thanks for the answer.
It is using Windows 10 Pro.
Message 3 of 33
(13,146 Views)
I think that points to a toolkit?  If so, you'll need to install the 64-bit version of the toolkit.  Oops looks like part of the install.  Maybe LV 64-bits had an issue installing?
Bill
CLD
(Mid-Level minion.)
Message 4 of 33
(13,131 Views)
  • Did you activate LabVIEW at full or higher or only "base"?
  • Are you running any unusual antivirus or security software?
Message 5 of 33
(13,116 Views)
Yes I have the full development system activated.
I am not running any antivirus. It is a clean installation of Windows 10.
I have tried to uninstall Labview 2019 64bit and install it again, but I get the same message. There are no error messages during installation, so I am not sure what else I can try.
Message 6 of 33
(12,888 Views)
Does anybody have a clue why lvanlys.dll cannot be loaded? It is quite fustrating... I have also tried to change things in the Bios, without luck.
Message 7 of 33
(12,326 Views)
When I use the dependency Walker on this dll I get many dependency errors. I guess it is not normal.
Message 8 of 33
(12,283 Views)
Is your BIOS updated to the latest rev?
-AK2DM
Message 9 of 33
(12,271 Views)
I have updated the Bios and the result is the same. I have also tried to install other versions of Labview 64bits (e.g. 2018) but still the same.
Message 10 of 33
(12,248 Views)
