How can I write a sum formula in LabView? Help!!
GerdW,
how do you divide two sum formulas`?
Message 11 of 24
(2,642 Views)
Hi Anni,
Look carefully at that CompoundMath node…
Message 12 of 24
(2,637 Views)
AnnihilationSpectrum,
It will be much better if you show YOUR code and data values instead of just asking "how to do"
Message 13 of 24
(2,634 Views)
dear artem and gerdw,
i build gerdw solution. I wrote numbers on the panel randomly and the results always give a zero.
Message 14 of 24
(2,629 Views)
Hi.
It's normal that you obtain that result as you make a sum from k to kr with k > kr, which is 0.
You also have to be careful as you didn't invert one of the entry on the compoundmath so you're doing only multiplications here and not a multiplication and a division.
P.S : you can also press ctrl+u once to clean-up a bit this diagram.
Message 15 of 24
(2,620 Views)
You write all 2354 element for "n", or create "zero filled" array with last element = 125?
And also you always take array size = (A-B) where A<B, so your array sunset is empty (length less than zero). Of course summ will 0.
Message 16 of 24
(2,626 Views)
Hi Anni,
No, you didn't!
As I said before: look carefully at this CompoundMath node! You can invert inputs and output of that function…
When your indices (k, kr) are in the order of 11000 then your input array "n" needs atleast that much elements. Did you input enough elements for the array???
You should use "known" inputs instead of some "random" ones!
Message 17 of 24
(2,608 Views)
Hello again. Left and right sides are not equal in spectrum. There's a background on the left. By using spectral data, they want me to implement the front panel to the formula in the picture. they want to match the left side of the spectrum to the right. im sorry my bad english.
Message 18 of 24
(2,563 Views)
Why?  How to, is what learning is all about!  Now, showing what's been failing, helps us teach, but I think that learning is preferable to trick or treating on these forums.
"Should be" isn't "Is" -Jay
Message 19 of 24
(2,553 Views)
Hi Anni,
So you should do your job!
Then apply that formula if it has been given to you!
(From the scale labels it rather looks like a histogram.)
Message 20 of 24
(2,546 Views)
