How can I write a sum formula in LabView? Help!!
I need to implement this formula in Labview.
but not on the formula node.
Could you help me please?
Message 1 of 24
(8,399 Views)
You need array index and for loop
Message 2 of 24
(8,384 Views)
Hi Anni,
for those sums in nominator and denominator you need an ArraySubset followed by SumArray function. No loops needed!
Message 3 of 24
(8,381 Views)
Thank you for your reply, but how? The formula is pretty easy, but for Labview it's hard for me. Could you show me? For example how can i write sum with index array in for loop
Message 4 of 24
(8,380 Views)
Hi GerdW,
I didnt find sum array. I need some exercise about math implementation. if you have a little bit time could you show me?
kind regards
Message 5 of 24
(8,366 Views)
Message 6 of 24
(8,355 Views)
Hi Anni,
did you ever tried to use Quickdrop? Ctrl-Space?
See this:
Please check the calculation, especially the inputs of those ArraySubset functions.
Message 7 of 24
(8,349 Views)
Gerd, you need ("end"-"start"+1) for length.
Message 8 of 24
(8,342 Views)
Hi Artem,
that's why I asked Anni to check the ArraySubsets… 😄
Message 9 of 24
(8,339 Views)
GerdW,
thanks for your helps, its very helpfull.
i tried , n_kl, n_kr and n are given always 0.
Message 10 of 24
(8,326 Views)
