Hi need explanation of this question
Hi thanks for the suggestion! so does that mean need to use the state machines?
Message 11 of 15
(990 Views)
Yes, you have several states. The state machine can be very simple.
Message 12 of 15
(984 Views)
You never need a state machine.
You could use a state machine to get the behavior you want.
There are (many, many) alternatives. I prefer a state pattern, but that's OO (and therefor very difficult 😉). For a small thing like this, I probably put everything in a class that keeps it's own state...
Message 13 of 15
(961 Views)
I agree, but it depends a little bit how broad the term is defined. (Something that retains a start tick across iterations and can be in several states (LED Skipped? Button pressed? 200ms elapsed? 1000ms elapsed? ) could already be called a (very primitive) state machine. 😉
Message 14 of 15
(943 Views)
Accepted by gavinng
Agreed.
Just trying to convey that a state machine is an option. Any solution should be a means to an end. Not something you feel like you need to (or, worse, are told to) use.
Message 15 of 15
(936 Views)
