Find and replace
Hi guys
Once more I have an question and maybe the answer can satisfy a lazy guy ;).
Is there a way to easily find and replace vis? I know the find-function (which is quite good) but if I want to replace one vi which is used several places, I have to right-click and replace them manually. Is there a function where I can also find them and click a replace button if I want to replace the vi or not (just like it is possible in MS Notepad or any other texteditor)?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 1 of 10
(5,922 Views)
I don't think there's something like that, I think the fastest way will be to save the old VI in the same name as the new VI (in a temp location), and then replace one of its instances with the new VI. Since the name will be identical, it will ask you if you want to replace. Then you can delete the temp.
I'm not sure whether saving one of the instances under a different name will affect all of them (I think it will), so you may have to close the app to force the change to take place. It's up to you to decide whether it's worth it or not.
___________________
Try to take over the world!
Message 2 of 10
(5,904 Views)
Hi tst
This may work if both vis are selfmade. But if I have one of the yellow ones, I can't replace it as you described.
There it may be helpful to have such a mechanism.
Anyway - thanks your answer.
Thomas
Using LV8.0
Message 3 of 10
(5,899 Views)
No, not function but there is a way.
Take advantage of the fact that LV will only allow you to have one VI of a particular name in memory at one time (like tst was suggesting).
1) Close all of your VI's (and LV just to be sure).
2) Open the VI that you want to include in your application and make sure it is the same name as the VI you want to replace.
3) OPen your top level VI. All of your VI will now point at the VI you pre-opened.
4) Do a "save as" on the pre-opened VI. NOw all of the calls to the VI in your app will be pointing a the new named VI.
5) Save all of your VI's and close everything.
Once you do this you will have achieved the same results as having done a "find and replace".
Ben
Message 4 of 10
(5,887 Views)
Hi Ben
Does this also work if I want to replace functions like queue-operations (enqueue, dequeue, ...)?
Thomas
Using LV8.0
Message 5 of 10
(5,881 Views)
Ben, I don't think your suggestion will work, because he wants to replace the yellow ones (the function VIs) and they don't seem to have names in the traditional sense. You can have a VI called "add.vi" and the add VI open at the same time.
___________________
Message 6 of 10
(5,876 Views)
Correct tst!
and NO Bechtho.
This procedure will only work if the object in questions shows up when you do a
Application Open >>> All VI's in memory
Sorry I was not able to help! (But that will not stop me from trying.)
Ben
Message 7 of 10
(5,866 Views)
Yes tst, you're right.
And I maybe don't want to replace all vis in one turn which means that I wanna have the possibility to control if a vi (or function) shall be replaced or not.
Using LV8.0
Message 8 of 10
(5,866 Views)
Well I am finally getting around to finsishing reading the upgrade notes for LV 8 and I found this on page 91of 108.
In LabVIEW 7.
x and earlier, you can replace an object on the block
diagram by right-clicking the object and selecting
Replace from the
shortcut menu. In LabVIEW 8.0, you can replace multiple objects or pieces
of text at once. Use the
Find dialog box to search VIs for VIs, objects, and
text. Then use the
Search Results window to replace all or only selected
items with other objects or text.
I should stasrt reading these relase notes sooner. Smiley Wink
Ben
Message 9 of 10
(5,738 Views)
Boy!   That's something I sure could have used a time or two!  I don't think there's an  existing, clever way of doing this.  However, in the future, if you build all your applications with generous use of subvi's it's a real easy matter to reload the thing with the modified subvi's, should the need arise.   I haven't run into any real performance issues with multiply nesting subvi's, but there may be some.  I think Dennis might be able to answer this better than I can.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
Message 10 of 10
(5,708 Views)
