How do I format 1D waveform array to output to intensity chart?
I've tried to modify the "Cont Acq&Graph Voltage-Int Clk.vi" example vi to output to an intensity chart. The problem is the chart only accepts a 2D array of input data, while the DAQmx vis are giving me a 1D array of waveform data.  How do I fix this?
Thanks in advance...
(3,571 Views)
There is a waveform array to XY pairs that gives you a 1D array of a cluster of 2 elements. Maybe you could manipulate this to get your 2D array. The intensity chart needs an XY location for a given Z value. These are for showing 3D data on a 2D chart. Can you post some sample data??
(3,565 Views)
  Thanks!  Here's an example of the first few samples of the data I'm getting, plus the header:
Channels 1
Samples 1000
Date 2006/07/24
Time 13:41:57.315999
Y_Unit_Label Volts
X_Dimension Time
X0 0.0000000000000000E+0
Delta_X 0.000100
***End_of_Header***
X_Value Dev1/ai0 Comment
 0.068936
 0.028033
 0.038671
 0.047368
 0.053086
 0.052326
 0.039342
(3,559 Views)
....actually, the samples should be in the Dev1/ai0 column.
(3,558 Views)
I figured it out:  use the "convert to Dynamic data" vi to convert the data into a type the intensity graph will recognize.
(3,549 Views)
