Downconvert VI Requests
Hi princejack,
as I said before: I had problems converting those VIs because of "mem corruption" errors. The VI in question was one of them...
Attached you'll find a picture of the BD!
Message Edited by GerdW on 03-11-2010 07:03 PM
Message 31 of 1,444
(6,346 Views)
oh thank you very much for the picture.
I don t know why there was this memory corruption...I m sorry again for disturbing and thanks a lot for your help.
A last question is possible to convert for me this file.zip too?
I found it on the forum but I cannot open the files because there are all made with  labview 2009.
Thank by advance,
Message 32 of 1,444
(6,326 Views)
Hi princejack,
now you attached that file the 3rd time. Why do you spam the forum with +3MB attachment?
As said before (and now saying for the 3rd time): I had severe problems with mem corruption when converting those files...
I had attached all files, where conversion was (easily) possible. For UI-Demo (which is nicely designed) there was no clear "Main.vi" or similar, and the first VI I tried to convert ended in mem corruption too. So I gave up converting this collection of VIs and CTLs.
Message Edited by GerdW on 03-12-2010 08:15 AM
Message 33 of 1,444
(6,301 Views)
oh sorry and thanks for all
Message 34 of 1,444
(6,288 Views)
Hy
Please can someone downconvert my Programm from LV7.0 to LV6.1
There is a @Tree.vi inside in which all Programm VI's are included!
Thanks!
Message Edited by Cardinal1664 on 03-15-2010 02:59 AM
Message 35 of 1,444
(6,256 Views)
Attached is in 6.1. It used the Build Error Cluster from OpenG, so you will need to get that separately.
Message 36 of 1,444
(6,235 Views)
thanks for your work!!!Smiley Very Happy
Message 37 of 1,444
(6,222 Views)
Down convert from 8.6 to 8.5
source LabVIEW version: 8.6
target LabVIEW version: 8.5
Message 38 of 1,444
(6,188 Views)
See if the attached will work. I did a block diagram cleanup operation on the VI since it was a mess.
Message 39 of 1,444
(6,175 Views)
Hello, I have receaved a Labview VI in version 9.0 but I have version 8.6 and I cannot open it. Could someone please save the attached VI in 8.6 or previous versions and post it back? Thanks a lot for your help.
Message 40 of 1,444
(6,150 Views)
