Complex exponential
Hello guys,
I want to multiply a signal by a complex exponential just as in the second picture. Is it correct the way I did it ? See the first picture below
The idea is to multiply a signal by a two ray channel (second pic). Is it correct to multiply a complex signal with the Doppler shift this way ?
Ali Sabra
Message 1 of 15
(6,030 Views)
@AliSabra wrote:
Hello guys,
Ali Sabra
It seems OK to me.
You can test by putting it in a for loop, or applying the formula to a ramp. That should give an output of a sin in Im and a cos in Re (or vice versa).
Message 2 of 15
(6,015 Views)
Thanks for your help.
Am I testing it correctly ?
Because there is no difference between the original signal and the Doppler shifted one.
Maybe because I am using a waveform generator instead of a simulated signal ? I dont see the I and Q
Message 3 of 15
(6,001 Views)
You're multiplying a single value (scalar) with a signal.
You should be multiplying a signal (the original) with the generated signal (a ramp put through the formula).
Both are functions or time, you now only have one function as time.
Message 4 of 15
(5,995 Views)
To see the I and Q, you'd need to split the signal up into the Im and Re of the result...
Message 5 of 15
(5,993 Views)
Can you send me a screenshot plz ?
Message 6 of 15
(5,991 Views)
Accepted by topic author AliSabra
Sure, but it's LV CG:
It's clear that multiplying the signals, adds the frequencies.
Message 7 of 15
(5,967 Views)
Look what is happening :S
Message 8 of 15
(5,942 Views)
Maybe the configuration isn't correct ?
Message 9 of 15
(5,936 Views)
I'm not into NXG enough to adive on that...
Apparently, those signals do work with complex numbers, but the ramp signal seems to be different than the sine?
Message 10 of 15
(5,926 Views)
