Case structure FPGA Target
Hello ,
i have a case structure in the Target VI and i want to control this case in the HOST VI !
How can i do this ?
(4,652 Views)
Hi Myrza,
send the control data from your host to the FPGA target.
There are example projects coming with LabVIEW explaining such kind of stuff…
(Did I already mention those examples?)
(4,650 Views)
Hello ,
Thank you,
Yes i tried to send the data with a FIFO ( Host to target )
But in the HOST side the fifo input is an 1D array , and in the Target side the fifo output is element !
I want to send just the number of the case (0,1,2,3) !
How will be the struture ?
(4,646 Views)
Hi Myrza,
what about using a simple control in the FPGA VI and access this control from your host (RT) VI?
Much easier than a FIFO here…
Again: there are example projects and VIs explaining all this!
(4,637 Views)
I'am new woth labview FPGA and i tried with the example project but i didn't find what i'am looking for,
can you please explain me how to use a simple control in the FPGA VI and access this control fromthe  host (RT) VI?
(4,633 Views)
Accepted by topic author MyrzaMBM
Hi Myrza,
Learn how to read and write FPGA controls/indicators from a host VI:
1. open LabVIEW.
2. Help menu -> Find examples.
3. Search for "fpga".
4. Select "Polling UI.lvproj" from the results.
5. Study the example.
(4,620 Views)
