Case structure FPGA Target
Hello ,
i have a case structure in the Target VI and i want to control this case in the HOST VI !
How can i do this ?
(4,524 Views)
Hi Myrza,
send the control data from your host to the FPGA target.
There are example projects coming with LabVIEW explaining such kind of stuff…
(Did I already mention those examples?)
(4,522 Views)
Hello ,
Thank you,
Yes i tried to send the data with a FIFO ( Host to target )
But in the HOST side the fifo input is an 1D array , and in the Target side the fifo output is element !
I want to send just the number of the case (0,1,2,3) !
How will be the struture ?
(4,518 Views)
Hi Myrza,
what about using a simple control in the FPGA VI and access this control from your host (RT) VI?
Much easier than a FIFO here…
Again: there are example projects and VIs explaining all this!
(4,509 Views)
I'am new woth labview FPGA and i tried with the example project but i didn't find what i'am looking for,
can you please explain me how to use a simple control in the FPGA VI and access this control fromthe  host (RT) VI?
(4,505 Views)
Accepted by MyrzaMBM
Hi Myrza,
Learn how to read and write FPGA controls/indicators from a host VI:
1. open LabVIEW.
2. Help menu -> Find examples.
3. Search for "fpga".
4. Select "Polling UI.lvproj" from the results.
5. Study the example.
(4,492 Views)
