Can I add a color to history
Is there any way to add a color to the History (see screenshot)?
When a colorbox control is changed manually the colors are automatically added here, but if I change the control via a local variable or property node, the colors do not get added. Therefore, is there some other way to manually add colors to this selection?
Shaun
Message 1 of 9
(3,973 Views)
Check the LabVIEW.in file for enties of the form
colorHistoryItemA
THis is where the custm collors are saved.
Ben
Message 2 of 9
(3,967 Views)
Hi Ben,
Thanks for the suggestion - it seems to be a good start, but unfortunately changes to the the INI file only seem to appear when LabVIEW restarts, and I'm looking for something that I can do within my application...  The search continues! 🙂
Shaun
Message 3 of 9
(3,957 Views)
Did you ever find anything?
Even writing those colorHistoryItemX keys with LabVIEW's internal config functions doesn't make the controls use them.
Message 4 of 9
(2,304 Views)
I found this: LabVIEW 20xx\resource\dialog\lvconfig.llb\LV Config Write Color.vi
Tags "colorHistoryItemA" through "colorHistoryItemK" seem to be applicable.
Sometimes it works, and sometimes it doesn't.  Haven't figured out why.
Message 5 of 9
(2,282 Views)
That's simply another wrapper to CfgWrite. It has the exact same effect as writing a number converted to hex as a string with LV Config Write String.vi.
They are, but they seem to be loaded into a state at start, and (at least usually) the state is stored over manual changes.
Do you mean you ever seen a value set to colorHistoryItemA work without restarting LabVIEW?
This might work if for instance no color control was loaded. But this would be completely unpractical.
I've written my own color dialog, yet again... At least now I can make it exactly how the customer wants it.
Message 6 of 9
(2,260 Views)
No.  I had thought so, but it turned out I was fooling myself.
Message 7 of 9
(2,255 Views)
I made this a long time ago.
Message 8 of 9
(2,250 Views)
Mine is a lot simpler, because my customer actually wants it simple.
Message 9 of 9
(2,206 Views)
