Programmatically find the chassi linked to a given cdaq module
Hi everyone,
I usually use "Find Harware.vi" to programmatically find the alias of a given device connected to the system.
However, when a use Cdaq module, I sometime needs to find on which chassi the module is plugged.
Does someone known a way to go from the module's alias to the chassi's ?
Have a nice day.
(1,205 Views)
Accepted by topic author lapingéant
Read the whole thread below, should be able to get the answer from that.
https://forums.ni.com/t5/LabVIEW/Get-PXI-Chassis-number-using-system-config-palette/m-p/3982393/high...
(1,158 Views)
Thanks ! It works !
(1,127 Views)
