Adding cDAQ-9189
This was originally posted in the DAQ section. I asked to move it here to get more views.
I am having problems adding my cDAQ-9189 chassis to MAX.
The chassis shows up in MAX, but when I click on Add Device I get error -201252 as shown below in the picture. I also tried a search in MAX of network devices and nothing shows up. I tried to add the chassis manually by entering the IP address and get "The device you requested could not be found on the network"
The PC I am using is running Windows 7 and is not connected to the internet. The chassis is directly connected to the PC via ethernet cable.
I have disabled Windows firewall and have no anti-virus software running.
I have enabled DHCP in networking on the PC, but have also tried using a static IP on the same subnet - neither work.
I am able to PING the chassis and I get a response back.
I have tried cross-over cables and ethernet switches.
I read through and tried suggestions found here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGv1CAG&l=en-US
Currently I am working with NI through a service request but wanted to know if anyone has had any similar problems.
Anyone have any ideas?
(3,466 Views)
So as not to waste people's time, the original post is here:
https://forums.ni.com/t5/Multifunction-DAQ/Problem-adding-cDAQ-9189-in-MAX/td-p/3838979
(3,444 Views)
