Scripting - Connector Pane Ref.
Hello everyone. I am trying to figure out if there is a way for labview to see if something is wired/connected to the connector pane. I have a bug in an application I am working on because it is showing all Indicators and Controls. But I only need the ones that are connected. Has anyone worked on anything similar to be able to give some insight on this?
(3,461 Views)
Your could set the default values of the controls to values that would never occur if real data is sent in; then when the VI runs compare the value in the control to the default value.
To actually determine if a pin is wired, you need a reference not to the VI, but to the instance of the subVI on the caller's block diagram (which would only be accessible in the development environment).  However I don't know of any way for a VI to determine from which subVI instance it was called.
It might be possible to do what you want with malleable VIs.
Or as a last resort, XNodes.
(3,445 Views)
What you are asking for was proposed as an idea on the LabVIEW Idea Exchange, but unfortunately was declined.
You may want to read that thread though.  New property of Method to indicate, if an input of a sub-VI is connected to some source inside the c...
(3,437 Views)
